PROBLEM
Feature Display Options are not available when configuring legend items in ArcGIS Pro
Last Published: November 15, 2023
In ArcGIS Pro, when opening the Element pane of legend items, Feature Display Options are not available, as shown in the image below.
Legend items in the Contents pane are selected to be configured in the Element pane.
Cause
One of the selected legend items’ features is not applicable to the Feature Display Options. Feature Display Options are not available for the clustering aggregation type, tile layers, vector tile layers, and scene layers. Refer to ArcGIS Pro: Dynamic legend items for more information.
Solution or Workaround
In ArcGIS Pro, select the applicable feature layer in the Contents pane to display Feature Display Options. Press and hold the Ctrl key to select multiple feature layers.
Feature Display Options are displayed when the applicable feature layer is selected from the Contents pane.
Alternatively, in the Contents pane, deselect the non-applicable feature layer instead. Press and hold the Ctrl key and deselect the feature layer.
In ArcGIS Pro, Feature Display Options are available in the Element pane when the non-applicable feature layer is deselected.
The non-applicable feature layer is deselected from the Contents pane and Feature Display Options are displayed.
Article ID: 000031400
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 9x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
