PROBLEM
Feature Analysis and Raster Analysis are disabled in ArcGIS Pro
First Published: July 8, 2024
Last Published: June 24, 2026
When working on an ArcGIS Pro project, the Feature Analysis and Raster Analysis toolboxes are unavailable on the Analysis tab.
The inactive Feature Analysis and Raster Analysis toolboxes
Cause
  • The account is not connected to an active ArcGIS Enterprise portal configured with a hosting server for the feature analysis toolbox or an ArcGIS Image Server for the raster analysis toolbox. Additionally, the Feature Analysis and the Raster Analysis toolboxes do not work if the active portal is ArcGIS Online.
  • The ArcGIS Pro account does not have spatial analysis privileges.
Solution or Workaround
Connect the ArcGIS Pro project to an active ArcGIS Enterprise account
Before connecting to the portal, ensure the ArcGIS Enterprise portal is configured with a hosting server to access the Feature Analysis toolbox or ArcGIS Image Server in the role of a raster analysis server to access the Raster Analysis toolbox. Refer to ArcGIS Enterprise on Windows and Linux: Specify the hosting server or ArcGIS Image Server: Set up an ArcGIS Image Server raster analysis site for more information.
  1. In ArcGIS Pro, add an ArcGIS Enterprise portal connection. Refer to ArcGIS Pro: Add a portal connection for further instructions.
  2. Set the ArcGIS Enterprise portal as an active portal. Refer to ArcGIS Pro: Set as active portal for further instructions.
Assign the appropriate licenses and privileges to the ArcGIS Pro account
To access the Feature Analysis toolbox, determine the type of licenses required for spatial analysis, and assign them to the account. Refer to ArcGIS Enterprise on Windows and Linux: Privileges granted to roles for further information.
Article ID: 000032914
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
