PROBLEM
Failed to sync and 'No permission to sync replica: <id>' error returned in ArcGIS Field Maps
First Published: November 8, 2024
Last Published: March 3, 2025
In ArcGIS Field Maps, attempts to sync a layer from an offline map fail when the layer is added via URL from a stand-alone ArcGIS Server with embedded credentials to ArcGIS Online or Portal for ArcGIS. The following error message is returned:
Error:
Sync Failed
In addition, the ArcGIS Field Maps logs further indicate the following error:
Error:
Unable to complete operation.
Cause
This is expected behavior. In ArcGIS Field Maps, a replica is created, and the owner is assigned in ArcGIS Server when the web map is first taken offline. In this instance, the owner's username is set based on the stored credentials in ArcGIS Server at the time the web map is taken offline. If the stored credentials are later updated, a mismatch occurs between the original owner and the user attempting to sync. The sync fails if the new username is not the original replica owner or an admin user with sufficient privileges. Refer to ArcGIS REST APIs: Sync permissions for more information.
Solution or Workaround
Only an organization's default administrator or a member with administrative privileges can perform the following workflows.
Update the stored credentials
Update the stored credentials for the ArcGIS Online or ArcGIS Enterprise item to revert to the original user.
Temporarily assign administrative privileges
Assign temporary administrative privileges to the member to allow the required layer to sync. Refer to ArcGIS Server: Modify a user or ArcGIS Server: Modify a role for more information.
As best practice, sync and delete existing maps in ArcGIS Field Maps before updating the username. Then, download a new offline area to create a new replica using the new username.
Article ID: 000034150
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
