PROBLEM
When running a webgisdr backup utility, an ArcGIS Server backup, or running the servicesExport function, the action may fail. Occasionally, the following error message is returned:
Error: Unsupported Image Type
This error is tied to a service metadata file, and the thumbnail's base64 encoding within the metadata file. Republishing the service fixes the issue. Identifying the corrupted service is important as errors are not displayed in the log pointing to the corrupted services.
The steps below describe how to identify corrupted services in ArcGIS Server using Process Monitor (Procmon).
Note: It is not necessary to define the parameters for the export process to run successfully.
The image below displays a corrupted service, highlighted in Process Monitor. The corrupted service is identified by the number of displayed items, and the highlighted service indicates only three items are displayed. This is the service to republish.
A successfully backed up service must display seven items, and the proper details listed as follows:
0: .. 1: .JPEG 2: iteminfo.json 3: iteminfouploadslist.dat 4: lifecycleinfos.json 5: manifest 6: metadata 7: thumbnail
Note: System/Utility services display only three items. This is by default, and does not indicate the service is corrupted or in a bad state.
Article ID: 000022507
Get help from ArcGIS experts
Start chatting now
