PROBLEM
When deploying a solution in the ArcGIS Enterprise portal, the following error message is returned:
Error: <Solution> failed to deploy
This error prevents the successful deployment of the selected solution and its associated content.
This issue occurs when HTTPS is not enabled for the portal. HTTPS is required for secure communication during solution deployment.
Enable HTTPS-only communication in the ArcGIS Enterprise portal. Refer to Portal for ArcGIS: Configure HTTPS for instructions. In Step 3, toggle on the Allow access to the portal through HTTPS only toggle button.
Article ID: 000038225
Get help from ArcGIS experts
Start chatting now
