PROBLEM
External open data groups are not displayed in ArcGIS Hub workspaces
Last Published: October 7, 2025
In the ArcGIS Hub workspace, checking the Open Data check box in the My Groups page on the Groups tab does not display external open data groups to be added to sites.
The Open Data check box in the ArcGIS Hub workspace
Cause
This is a known limitation. The new workspace does not currently support adding open data groups from external ArcGIS Online organizations.
Solution or Workaround
Use the ArcGIS Hub classic edit mode to add external open data groups to sites.
The classic edit mode is supported until June 2026.
  1. Open ArcGIS Hub and log in using the ArcGIS Online organizational account.
If ArcGIS Hub is previously configured to work with workspaces, proceed with Step 2. Otherwise, skip to Step 5.
  1. In My workspace, click Settings.
  2. In Settings, toggle Workspaces off and click Save.
The Workspaces toggle button
  1. Click the username on the top right and select Overview from the drop-down menu.
The Overview option
  1. In the Opt-in to workspaces window, click Close.
If there is no existing site available, create a new one before proceeding to the next step. Refer to ArcGIS Hub: Create a site for instructions.
  1. On the Overview tab, click the site to add the open data group to it.
  2. In the Hub site, on the top-left corner, hover over the site's tab and click Groups Manager.
The Groups Manager option
  1. On the Groups page, click the Add Groups The Add Groups icon icon.
  2. In the Select groups to add window, under Filters, check Open Data and uncheck My Organization.
The Open Data and My Organization check boxes
  1. Check the check box next to the group to be added to the site and click Add.
The open data group
Article ID: 000037213
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
