PROBLEM
When using the Select By Attributes dialog in ArcMap, expressions can be saved into an expression file (.exp). These files can be loaded into the Select By Attributes dialog for later use.Although an .exp file can be opened and viewed with a text editor to see the stored expression, the same file returns a Unicode string if read into a variable in Python.For example, an .exp file can be opened in Notepad to see that the expression is "OBJECTID" = 1, but if the same .exp file is read into Python it returns "\000O\000B\000J\000E\000C\000T\000I\000D\000"\000 \000=\000 \0001\000 for the expression.
The .exp files are encoded.
Code:
# Variable: Path to .exp file
text = r"C:\VM_SHARE\Expression.exp"
# Process: Open .exp file for reading
file = open(text, 'r')
# Process: Read first line of .exp file
line = file.readline()
# Process: Decode line
.exp = line.decode('utf-16', 'ignore')
# Message: Return message to display
print exp
# Process: Close file object
file.close()
Article ID:000011585
Get help from ArcGIS experts
Download the Esri Support App
