PROBLEM
Exporting a map or layout in ArcGIS Pro displays turned-off layers in the output file
First Published: November 11, 2021
Last Published: November 11, 2021
In ArcGIS Pro, when exporting a map or layout containing KML or KMZ data to other file types, such as PDF, JPEG, PNG, or TIFF, turned-off layers are visible in the output file. In this example, all the KML layers except LAKE CATHERINE GeoLines are turned-off, displaying only the GeoLines layer on the map.
The Contents pane showing few layers turned-off and not visible on the map.
The image below demonstrates all the layers, including the turned-off layers, remain visible in the exported PDF file.
Map with all layers including the turned-off layers are exported to PDF.
Cause
This is a limitation when exporting a map or layout containing KML or KMZ files.
Solution or Workaround
As a workaround, convert the KML or KMZ files to geodatabase feature classes using the KML To Layer tool, and use the output feature classes in the map or layout to export.
  1. In the Geoprocessing pane, search for and open the KML To Layer tool.
    1. For Input KML File, select the KML or KMZ file.
    2. For Output Location, select a folder to locate the output geodatabase.
    3. For Output Data Name, set a name for the output data.
The KML To Layer tool converts KML or KMZ files to geodatabase feature classes.
  1. Click Run. The output data is added to the Contents pane and on the map. In this example, the output contains three layers: Points, Polylines, and Polygons. The output data is dependent on the original features of the KML or KMZ file.
  1. In the Contents pane, remove or turn-off the original KML or KMZ files.
  2. Turn-off the new layers as desired, and leave the other layers turned-on to be displayed in the exported file. In this example, only the Polylines layer is turned-on.
The undesired layers are turned off in the Contents pane before exporting the map or layout.
  1. Export the map, or create a layout and export the layout.
The image below shows the map exported to PDF, displaying only the GeoLines layer.
The exported PDF file displays only the turned on layer.
Article ID: 000026769
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
