PROBLEM
Exporting a feature class or table on a computer in which the locale is set to something other than English fails in many cases.
ArcGIS uses the Microsoft ODBC Text File driver. The Microsoft ODBC Text File driver defaults to a comma as the delimiter. This conflicts with the locale's decimal delimiter, also a comma, and the create table fails.
[your_file.txt]
Format=TabDelimited
This must be done for each file to be exported. Search the Microsoft Website for 'schema.ini' for more information on the 'schema.ini' file.
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
ESRI cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Jet\4.0\Engines\Text\Format
Article ID:000010904
Get help from ArcGIS experts
Download the Esri Support App
