PROBLEM
Exported Successfully! However, it seems you don't have permission to share the template item to the template group specified in your organization
The following message may be returned when exporting a template from a Web AppBuilder application:
"Exported succcessfully! However, it appears that you don't have permission to share the template item to the template group specified in your organization.
You need to manually add it to the group once it is accessible."
User-added image
Cause
This message appears when Portal for ArcGIS or ArcGIS Online is configured with the Default Configurable Apps group. This group contains all of the default application templates used to make apps, but it is not possible to share additional templates with the group.
Solution or Workaround
If Portal for ArcGIS or ArcGIS Online is configured with the Default Configurable Apps group, a custom group must be created and set as the Configurable Apps group. You can also share the default templates with the custom group as well, so that end users can also have those as options when creating apps.
Please see the below workflow:
  1. Create a group
  2. Check the Status option that says Organization (Users within your organization can search for and find this group.
  3. Navigate to My Organization > Edit Settings > Map > Configurable Apps. In the drop-down, select the group from Step 1.
  4. For end users to also have the option to use the default templates, check the box that says Share the Esri default configurable apps to this group when you click Save.
  5. Click Save on the upper left of the page.
Article ID: 000017176
Software:
  • ArcGIS Web AppBuilder
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
