PROBLEM
In a query with filter in Java Connector, the number of returned records is less than expected.
By default, when Java Connector sends a <GET_FEATURES> request, attribute "checkesc" is "false". Attribute "checkesc" is used to determine if the response should include escaped characters for ampersand, single quote, double quote, less than, and greater than. For example, if the value for SUB_REGION is "P&NW", then:
When checkesc="false", in the response the value of SUB_REGION is "P&NW".
When checkesc="true", the value of SUB_REGION is "P&NW".
The first response will cause an error when Java Connector parses it, and the corresponding record will be discarded.
Code:
Filter.setWhereExpression("CNTRY_NAME LIKE '%A%'");
Filter.setCheckesc(true);
Article ID:000005837
Get help from ArcGIS experts
Download the Esri Support App
