PROBLEM
In some instances, when creating an ortho mapping workspace for drone imagery in ArcGIS Pro, the following error messages are returned:
Error: 80042019: Could not build mosaic dataset item. [ID: 5, URI: 'D:\ArcGIS Sample Test 2019\21 21473\DJI_FC6510\DJI_0238.JPG']
Error: Error: 80004005: The altitude parameter is missing. Please input the flight height above ground height.
Error: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (https://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Error: Failed to execute (AddRastersToMosaicDataset).
These errors occur if the altitude values of the imported drone imagery are negative when added to the Image Collection pane. This issue is specific to drone imagery from the DJI6000 series FC camera models. This is a known issue, logged by Esri as a defect. Refer to BUG-000119757.
To resolve this issue, use one of the following workarounds:
Create and import the geolocation GPS text file
 to import the created CSV file.
![All values in the Alt [Z] are positive values](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000021473/00N39000003LL2C-0EMf2000000rp5L.png)
The image below shows the ortho mapping workspace successfully created without any errors.
Use Drone2Map for ArcGIS to create an orthomosaic
After creating a new project in the Drone2Map for ArcGIS application, generate an orthomosaic from the project images. Refer to Drone2Map for ArcGIS: Process single projects for more information.
Note: The Drone2Map for ArcGIS application can be downloaded from ArcGIS Marketplace: Drone2Map for ArcGIS.
Note: Assign the Drone2Map for ArcGIS license to the ArcGIS Online account. Refer to ArcGIS Online: Manage licenses for more information.
The image below shows the orthomosaic successfully created in the Drone2Map for ArcGIS application.
Article ID: 000021473
Get help from ArcGIS experts
Start chatting now
