PROBLEM
Error 000594 or 000595 occurs when exporting a shapefile to a personal geodatabase
First Published: April 7, 2017
Last Published: July 14, 2026
When exporting a shapefile to a personal geodatabase, an issue may occur that returns the following generic errors, "Error 000594" or "Error 000595".
Cause
There are several reasons for these issues, but typically the problem is due to:
  • The size of the shapefile being too large for a personal geodatabase.
  • The shapefile containing broken geometry.
  • The shapefile being irrecoverably corrupted.
Solution or Workaround
Depending on the reason, use the following workarounds to solve the issue.
  • Ensure the size of the shapefile does not exceed 2 GB before exporting it to a personal geodatabase. If reducing the size of the shapefile cannot be done, use a different geodatabase type with a larger capacity, such as a file geodatabase or an enterprise geodatabase. Personal geodatabases use the Microsoft Access data file structure (.mdb) which supports geodatabases limited to 2 GB or less in size.
    The effective size is between 250 and 500 MB before database performance starts to slow down.
    For a comparison of the different types of geodatabase and their sizes, see Types of geodatabases.
  • Ensure that the shapefile does not have any broken geometry before exporting it to the personal geodatabase. See Checking and repairing geometries for more information.
  • If the shapefile is corrupted and cannot be recovered with the methods suggested in How To: Recover a corrupt shapefile, create a new feature class in the personal geodatabase and load the data from the shapefile to the empty feature class using the Load Data tool.
Article ID: 000014197
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
