PROBLEM
Empty output generated using Erase in ArcGIS Pro with perfectly overlapping polygons
First Published: October 4, 2023
Last Published: March 31, 2026
In ArcGIS Pro, the Erase tool runs successfully with an empty output generated and returns the following warning message:
Warning:
000117: Warning empty output generated.
Warning 000117 on the Erase tool
Cause
The parameters are configured with identical inputs or the polygons overlap each other perfectly. When the input feature and erase feature have the same feature layer, the tool erases everything within the features and returns an empty feature. The situation is similar when the input and erase feature are different but overlap each other completely, erasing everything within the feature.
Solution or Workaround
Ensure the overlapping polygons do not align
Overlapping polygons
The borders of the polygon can be edited to not completely overlap each other. Refer to ArcGIS Pro: Reshape a line or polygon feature to edit a polygon border. Alternatively, another overlapping polygon can be selected to replace one of the parameters for the Erase tool.
Ensure the input parameters are different
Ensure the feature layers for the Input Features and Erase Features parameters are different.
Erase tool with parameters
Article ID: 000031297
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
