PROBLEM
Element is not rendered when a filter action is applied to the data in ArcGIS Dashboards
First Published: July 22, 2022
Last Published: July 22, 2022
When a filter action is applied to the data in a dashboard's category selectors, the element is not rendered when the None option is selected. For example, the message in the image below appears on an indicator element when the None option is selected in the category selector after the filter action is applied to the data.
Error:
Selection required on one or more elements
Message when element is not rendered
Cause
The 'Render only when filtered' option is checked and applied to the filter action in the dashboard's category selector.
Solution or Workaround
  1. In ArcGIS Dashboards, under the Header tab in the Layout panel, browse to the category selector.
  2. Click the Options Options icon button.png button next to the category selector and click Configure from the Options to open the Category selector window.
  3. On the Actions tab of the Category selector window, click Filter to expand the section of the action.
  4. Uncheck the Render only when filtered option.
Window to uncheck the Render only when filtered checkbox.
  1. Click Done in the window's lower-right corner to save the changes made to the filter action.
Article ID: 000027932
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
