PROBLEM
Element displays as 'No Data' and 'Cannot Access Data' in ArcGIS Dashboards
First Published: July 3, 2020
Last Published: November 22, 2022
A data-driven element backed by published data referencing a geodatabase source displays as 'No Data' and 'Cannot Access Data' in ArcGIS Dashboards.
The No Data and Cannot Access Data messages in ArcGIS Dashboards
Cause
In a dashboard, elements such as an indicator, gauges, pie charts and serial charts rely on the underlying data source's ability to generate summary statistics when queried. If the layer is incapable of performing statistics, the necessary summary statistics are not generated.
Solution or Workaround
Use query layers to query data from the database or geodatabase. Refer to ArcGIS Blog: Using query layers in Operations Dashboard for more information.
Article ID: 000023698
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
