PROBLEM
Sections of the HTML code may be repeated or incomplete when using MapObjects IMS (MOIMS) to serve HTML web pages to clients. As a result, certain sections or elements of the web page appear duplicated or incomplete when viewed in a browser.
There is a limit to the number of times the MOIMS Weblink.WriteString method can be called when creating an HTML document for the client. This limit is system-dependent. The duplicate HTML code results when this limit is exceeded.
Do not use WriteString to create the HTML document on the client. Do the following instead:
1. Use the file editing functions available in your programming environment to write the lines of HTML into a new text file with a .html extension.
2. Use the MOIMS WebLink.WriteFile method to send the .html file to the client. For example:
Code:
Dim bWorked as Boolean
bWorked = WebLink1.WriteFile "C:\temp\topframe.html"
Article ID:000002154
Get help from ArcGIS experts
Download the Esri Support App
