PROBLEM
DRAWW distorts map compositions and freezes system
Solution or Workaround
Product: PC ARC/INFO 3.4.2b
Platform: PC
Question:
When I attempt to draw a map composition in DRAWW, it distorts the lines and locks up the computer.
Cause:
Possible memory conflict between Windows and something else loaded in upper memory. One possibility is the RAMDRIVE.
Answer:
Try using EMMEXCLUDE=A000-EFFF under the 386Enh] section of the system.ini. If that improves the situation, then try to determine which driver is causing the problem. One approach is to REM out the drivers loading in upper memory one at a time. Once the driver has been isolated, then find out the specific memory address using either MEM /DEBUG /P or MSD under the TSRs button. Then exclude this portion of the memory only under EMMEXCLUDE.
Article ID:000001658
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
