PROBLEM
Dragging multiple ArcIMS services into ArcMap works improperly
This problem is addressed in ArcGIS 8.1.2.
Dragging and dropping more than one service into ArcMap may not work properly.
Cause
The problem shows up differently, depending on the operating system on which ArcMap is run:
WINDOWS 2000:
1. When dragging and dropping an image service and a feature service into ArcMap, only the feature service gets added.
2. When dragging and dropping two feature services into ArcMap, only the first feature service gets added.
3. When dragging and dropping two image services into ArcMap, ArcMap will crash.
WINDOWS XP:
When dragging and dropping two services into ArcMap, the No Drop mouse icon appears, and the services cannot be added to ArcMap.
Solution or Workaround
This problem is resolved in version 8.1.2. There is no work-around for this issue; installing version 8.1.2, or a later version is recommended.
Article ID:000004398
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
