PROBLEM
Download option unavailable for KML in ArcGIS Enterprise portal and ArcGIS Online
First Published: December 10, 2025
Last Published: January 21, 2026
KML files in the ArcGIS Enterprise portal and ArcGIS Online are widely used for data visualization, integration with web maps, and adding annotations. However, these platforms occassionally do not display the Download option to download the KML files for further use. This limitation affects data accessibility, prevents offline use, and limits sharing and integration across different GIS platforms.
The Download option not available on the Overview tab
Cause
KML files added to ArcGIS Online or the ArcGIS Enterprise portal are stored as item files and are not published as hosted or non-hosted feature layers. As a result, they do not consistently expose the standard Download option available for feature layer items. Refer to Portal for ArcGIS: KML and ArcGIS Online: KML for more information.
Solution or Workaround
Download the KML through ArcGIS Online
  1. Log in to ArcGIS Online and click Content > My Content.
  2. Navigate to the KML file, click Options and select View details.
  3. On the Overview tab, scroll to the Details section and under URL, click View. The KML file downloads automatically.
The URL for KML file on the Overview tab
Download the KML through the ArcGIS Enterprise portal
  1. Log in to the ArcGIS Enterprise portal and click Content > My Content.
  3. On the Overview tab, share the file with the public. Refer to Portal for ArcGIS: Share items with everyone for instructions.
  4. On the Overview tab, scroll to URL, and click View. The KML file automatically downloads.
The URL for KML file on the Overview tab in ArcGIS Enterprise
Access to the KML file via the URL requires sufficient privileges. If the item is not shared publicly or the account does not have the required permissions, clicking View will redirect to the ArcGIS Portal Directory login page. After successful authentication, the KML file will download automatically.
The URL link redirects to ArcGIS Portal Directory
Article ID: 000039512
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
