Solution or Workaround
Arcs appear jagged while digitizing with a NUMONICS ACCUGRID A90HBL in stream mode of ARCEDIT. Zooming in proves those arcs are jagged.
Cause
This is caused by an EPROM chip inside the NUMONICS ACCUGRID A90HBL. This chip has a smoothing algorithm that conflicts
with the way ARC/INFO interprets stream mode data.
Solution
Contact the digitizer's manufacturer in order to obtain another EPROM, one that will disable the smoothing algorithm. Also, ask for the manufacturer for specific instructions to replace this chip.
