PROBLEM
DibExporter does not support IExporter::Resolution property
If the ArcMap IExporter object is created and set as a DibExporter, Visual Basic returns an error when the user attempts to set the IExporter::Resolution property.
Cause
The property is not supported by the interface.
Solution or Workaround
The output BMP will always be 72 dpi. If you use the Height and Width properties of the DibExporter, it is possible to create an image that, when resized in a graphics application, is of the desired size and resolution.
When resizing in a graphics application, be sure that the image is not resampled when resizing. This will maintain the same total number of pixels in the new image thus changing the image resolution. This option is variously referred to as 'Maintain original size', 'Resample Image', or 'Actual/Print Size'.
Article ID:000003019
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
