PROBLEM
Definition Query is ignored by Spatial Analyst functions
Using a Definition Query for a layer is ignored by Spatial Analyst functions.
After setting up a query, running a Spatial Analyst function, such as Convert Features to Raster, all features, including those not displayed, are converted to raster.
Cause
This is a known issue with ArcGIS 8.1.
Solution or Workaround
This problem has been resolved in ArcGIS 8.1.2.
In ArcGIS 8.1, you can use Select By Attributes to get around this problem.
  1. Click the Selection menu and click Select By Attributes.
  2. Set up a selection and click Apply.
  3. Run the Spatial Analyst function.
    The analysis will only occur on the selected features.
Article ID:000004118
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
