PROBLEM
Data Interoperability Workbench fonts in FME Options are too small
Last Published: December 28, 2023
In FME Workbench, when examining the properties of an .fmw file in FME Options, the fonts may be too small to read.
FME Options fonts too small in FME Workbench
Cause
This is a known issue with text scaling in FME Workbench when using monitors with a resolution higher than 1080p. This issue mainly affects FME 2022 and older versions.
Solution or Workaround
An adjustment must be made to the font size to enlarge the text.
  1. In Windows File Explorer navigate to:
C:\Program Files\ArcGIS\Data Interoperability for ArcGIS Pro
  1. Right-click fmeworkbench.exe and select Properties > Compatability tab. The following shows the Properties dialog.
Compatability tab
  1. Click Change high DPI settings then enable High DPI scaling override and set it to use System Scaling, as shown in the next image.
High DPI override
If Data Interoperability fonts do not repond immediately, it may be necessary to close the Data Interop Workbench, save the ArcGIS Pro project, then close and reopen.
Article ID: 000031751
Software:
  • ArcGIS Desktop
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
