PROBLEM
CUSTOMLENGTH for dimension features does not work correctly
When trying to change the CUSTOMLENGTH attribute for a dimension feature, the entered length does not display correctly.
Cause
The dimension feature class was created using a geographic coordinate system, such as North American Datum 1983 (GCS_NAD_1983) or WGS 1984 (GCS_WGS_1984).
Solution or Workaround
When creating the dimension feature class in ArcCatalog, select or import a Projected Coordinate System, such as State Plane or UTM.
    Article ID:000009172
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
