PROBLEM
Custom styles are not listed in the Symbology pane in ArcGIS Pro
Last Published: November 1, 2022
Existing custom symbols do not appear in the list of symbols of the Symbology pane.
Cause
The connection with the data source with the Favorites.stylx file is damaged.
Solution or Workaround
  1. Open the Styles folder in Catalog View from the View tab > Catalog View, or from the Symbology pane > Format Symbols > Manage Styles button, as shown in the next image:
  1. If there is a red exclamation mark in the Favorites, click it and reconnect it with the data source. These are saved by default in:
C:\Users\<username>\AppData\Roaming\Esri\ArcGISPro\Favorites.stylx
  1. Alternatively, right-click the Styles folder, and click Add > Add Style and insert the .stylx files.
Article ID: 000028088
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
