PROBLEM
Creating an address locator with a multipoint feature class crashes ArcMap and ArcGIS Pro
First Published: December 5, 2018
In some instances, creating an address locator with a multipoint feature class as the reference data using the Create Address Locator tool in ArcMap or ArcGIS Pro crashes the software.
Cause
The issue occurs because there are multiple points associated to a single address or object ID. So the address locator is unable to identify which point is the correct reference. This creates a conflict for the address locator to find addresses.
Solution or Workaround
To circumvent the issue in ArcMap or ArcGIS Pro, convert the multipoint feature class to a single-point feature class using the Multipart To Singlepart tool. For more information, refer to the solution section of the article Problem: The Intersect tool generates a multipoint feature class for how to use the Multipart To Singlepart tool. When the features are converted to single-points, create the address locator using the new single-point feature class as the reference data.
The image below shows an address locator created using the new single-point feature class as the reference data.
Address locator is created using the singlepoint feature class
Article ID: 000019015
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
