PROBLEM
When creating a new survey in ArcGIS Survey123 Connect, the application stops responding when converting the XLSForm, as seen below.
If Survey123 Connect is closed and reopened, and the survey is refreshed, the following error is displayed:
Error: Error: 201 Error transferring https://<SomeURL>/slx2xform - server replied: Forbidden
This issue occurs because the Survey123 REST API URL in Survey123 Connect Settings is modified, and is not the default web address that connects to the ArcGIS conversion service. The conversion service converts XLSForm files to the xForm format that can be displayed in Survey123 Connect and the field app. When Survey123 Connect is unable to connect to the conversion service, the conversion fails.
To reset the Survey123 REST API URL to the default web address of the conversion service, follow the steps below.
Article ID: 000016912
Get help from ArcGIS experts
Start chatting now
