PROBLEM
CreateMobileMap_mobile module is missing in the Python window
CreateMobileMap_mobile module is missing in the Python window.
This occurs in two possible scenarios:
• ArcGIS Mobile 10.1 is installed before ArcGIS Desktop 10.1.
• ArcGIS Mobile 10.1 and ArcGIS Desktop 10.0 are installed and then ArcGIS Desktop is upgraded to version 10.1.
Cause
Python cannot locate the mobile path file which sets the ArcGIS Mobile geoprocessing tool path for Python.
This chart shows the relationships between software versions and file information.
[O-Image] Software and File Information
Solution or Workaround
Use the Repair option from ArcGIS Mobile Installation to add the mobile path file:
• For ArcGIS Desktop 10.0, use C:\Python26\ArcGIS10.0\Lib\site-packages.
• For ArcGIS Desktop 10.1, use C:\Python27\ArcGIS10.1\Lib\site-packages.
  1. Click Start > Settings > Control Panel.
  2. In the Control Panel, click 'Add/Remove Programs' (Windows XP) or 'Programs and Features' (Windows Vista and Windows 7), click ArcGIS Mobile Application, and then click Uninstall/Change.
  3. Choose the Repair option.
  4. Follow the instructions and complete the repair process.
    The CreateMobileMap_mobile module is now set to the correct location.
Article ID:000011188
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
