PROBLEM
Create World File option for Export is disabled in ArcMap
When exporting a Map Document from ArcMap to a TIFF or BMP, the Create World File option is disabled.
Cause
This option is only available in the Data View and not in the Layout View.
Solution or Workaround
  1. Select the View Menu > Data View option.
  2. Select the File Menu > Export.
  3. Specify TIFF or BMP for the Save As Type.
  4. Click Options.
  5. Check the Create World File option.
  6. Click OK.
  7. Specify an output name.
  8. Click Export.
Article ID:000006671
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
