PROBLEM
Coverage to Geodatabase wizard output feature class is incorrectly named
The output geodatabase feature class is incorrectly named after using the Coverage to Geodatabase wizard. The default name is used instead of the specified name.
Cause
The default name is used for the output, instead of the one you specify, when you follow this sequence:
1. Specify an output name.
2. Click the Back button from the 'New feature class names and additional options' panel.
3. Click the Next button to the Summary panel.
Solution or Workaround
Check the output name in the Summary panel to ensure it is correct. If it is not:
  1. Click the Back button until you get to the panel titled 'New feature class names and additional options.'
  2. Specify the desired output feature class name again.
  3. Click forward to the Summary panel and make sure the output feature class name is correct.
Article ID:000003109
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
