PROBLEM
Converting event theme to shapefile produces bad shapefile
After performing an Add Event Theme on a .dbf file, and then converting this to a shapefile, the attributes are either blank or contain zeros.
Cause
The new shapefile has the same name as the .dbf file and resides in the same directory.
Solution or Workaround
  • Rename the new shapefile so its name is different from the .dbf file.
  • If the new shapefile must have an identical name to the .dbf file, place the shapefile in a different directory.
Article ID:000003846
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
