PROBLEM
Converting a coverage route system to PolyLineM shapefile can create duplicated vertices or extra parts.
The ArcCatalog/ArcToolbox coverage to shapefile conversion tools use the ArcInfo Workstation defined layers LAYEREXPORT command to create a shapefile. This code has not been optimized to reduce the number of vertices and parts.
Use ArcMap to export a coverage route system to shapefile. ArcMap uses the FeatureDataConvertor object behind the scenes. This object has code that has been optimized to reduce the number of vertices and parts.
Article ID:000003399
Get help from ArcGIS experts
Download the Esri Support App
