PROBLEM
Coded value domain descriptions not included when exporting data in ArcGIS Pro
First Published: March 27, 2024
Last Published: September 18, 2026
In ArcGIS Pro, when exporting data with coded value domains to formats such as a shapefile or KML, the exported layer or table contains only the domain code values and not the corresponding domain descriptions.
The image below shows the attribute table of the feature layer before exporting. In this example, the City, Level, District, and Type fields contain the domain descriptions.
Attribute table before export
The image below shows the attribute table with only the code values displayed after exporting to a layer or table.
Attribute table after export
Cause
The 'Transfer field domain descriptions' environment setting for exporting features is not enabled, or 'Use domain and subtype description' is not enabled when exporting to Excel. When enabled, these settings transfer domain descriptions to a workspace or format that does not support domains. Otherwise, ArcGIS Pro includes only the domain code values.
Solution or Workaround
Change the environment setting when exporting features
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the feature layer and navigate to Data > Export Features.
  3. In the Export Features pane, on the Parameters tab, ensure the feature layer is selected for Input Features.
  4. Specify a name for Output Feature Class, and click Browse Browse.png to select a save location for the feature class.
Configure the parameters in the Export Features dialog box
  1. On the Environments tab, expand Fields and check the Transfer field domain descriptions check box.
  2. Click OK.
Configure the Environments tab in the Export Features dialog box
Change the environment setting before exporting to another format
  2. On the Analysis tab, in the Geoprocessing group, click Environments.
  3. In the Environments window, under Fields, check the Transfer field domain descriptions check box.
  4. Click OK.
Configure the Environments window
  1. Run the required export or conversion tool.
The image below shows the exported table with the domain description fields included when using the Transfer field domain descriptions environment.
Attribute table with domain descriptions
Include domain descriptions when exporting to Excel
In ArcGIS Pro, use the Export to Excel tool to export data to an Excel file. Refer to ArcGIS Pro: Export a table to Excel from a map for instructions. In Step 4, check the Use domain and subtype description check box to include domain descriptions in the exported Excel file.
Article ID: 000032226
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
