PROBLEM
Clipping data at a projection horizon doesn't always work
Each projected coordinate system has a horizon, an area beyond which data isn't valid. At times, ArcMap does not clip geometries at the horizon's edge correctly. The clipping works correctly only the first time the coordinate system is used in a session.
Cause
This is a software limitation. The horizon and geometry domains are set incorrectly, which causes the intersection and difference results to be rejected.
Solution or Workaround
Restart ArcMap.
Article ID:000003726
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
