PROBLEM
Clearing the coordinate system doesn't automatically re-enable the Map Units control
When clearing a data frame’s coordinate system on the Coordinate System tab of the Data Frame Properties dialog box, the Map Units control on the General tab stays disabled.
Cause
The Map Units control should automatically re-enable whenever the data frame's coordinate system is cleared. This is a known issue.
Solution or Workaround
  1. Click OK to dismiss the Data Frame Properties dialog box after clearing the coordinate system.
  2. Open the Data Frame Properties dialog box again. You will notice that the Map Units list box on the General tab is now enabled.
Article ID:000002783
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
