PROBLEM
CleanShapefile utility isn't available in ArcGIS 9.0
The CleanShapefile.exe utility was installed with the ArcObjects Developer Kit at ArcGIS version 8.x. The utility looped through shapefile features and created a new shapefile containing simple geometry.The CleanShapefile utility is no longer installed with the ArcObjects Developer Kit.
Cause
CleanShapefile has been replaced with the Repair Geometry tool available in ArcToolbox. Repair Geomtery is available to all ArcGIS license levels and can be used with both shapefile and geodatabase feature classes.
Solution or Workaround
  1. Open ArcToolbox.
  2. Navigate to Data Management Tools > Features > Repair Geometry.
  3. Browse to a shapefile or geodatabase to use with the tool.
    ArcToolbox also contains a Check Geometry tool that creates a DBF or geodatabase table that lists all non-simple features found in a feature class. This tool only reports the features with non-simple geometry; it does not repair them. The Check Geometry tool is found under Data Management Tools > Features > Check Geometry.
Article ID:000006898
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
