PROBLEM
When either modifying a circular arc by moving a vertex so that the radius is large, or creating a new circular arc with a large radius, incorrect results of varying severity could display. The most extreme situation is that the map display is corrupted by a permanent artifact that cuts across the extent of the map.
The stored geometry is not affected.
This is a known problem.
Article ID:000003532
Get help from ArcGIS experts
Download the Esri Support App
