PROBLEM
If the Shared Edit Tool, Integrate Command, or the AutoComplete Polygon edit task are used to edit features that contain circular arcs, the arcs will be converted to straight line segments once the edit operation is complete.
If topology is used to complete an edit operation of features that contain circular arcs, the arcs will be converted to straight line segments. The Shared Edit Tool, Integrate Command, and the AutoComplete Polygon edit task use topology (shared edges) to complete an edit operation.
If you need to retain parametric shapes, use the Edit tool to select entire features and edit adjacent features independently. Use snapping to ensure coincidence.
Article ID:000003577
Get help from ArcGIS experts
Download the Esri Support App
