PROBLEM
Changing versions clears the snap environment
ArcMap saves the snapping environment inside of the map document. However, changing the version a layer points to changes the layer's source. When a layer's source changes, snap agents set for that layer are removed.
Cause
Changing the version an ArcSDE layer references in ArcMap is similar to changing the layers source.
Solution or Workaround
Once the version has changed, snap agents that were set for that layer need to be added from within the snap environment dialog.
Alternately, you could write a VBA script to accomplish the same task.
Article ID:000003314
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
