PROBLEM
Changing the output options for a geocoding service in the Find dialog box causes the Find dialog box to search again for candidates
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
When the output options for a geocoding service are changed in the Geocoding Options dialog box, the Find dialog box searches again for candidates for the address.
Cause
This is a known issue with the software.
Solution or Workaround
There is no work-around for this problem. This problem will be addressed at a future release.
Article ID:000004769
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
