PROBLEM
Cannot view SDE annotation features in ArcInfo Desktop
SDE 3.0.2 annotation features may not display in ArcInfo Desktop if there are other entity types associated with the SDE layer.
Cause
ArcCatalog and ArcMap will not display SDE layers that have multiple geometric entity types.
Some methods of creating SDE annotation layers may add point and line entities to the layer's definition.
Solution or Workaround
Remove the line feature entity type from the SDE layer. Your SDE administrator can do this using the SDELAYER command at a system prompt:
Code:
sdelayer -o alter -l table,column -e pA -u DB_User_name -p DB_User_password
The SDELAYER command is located under bin in the SDE installation directory.
Article ID:000002121
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
