PROBLEM
Cannot use ArcCatalog to copy/paste an SDE 3.x layer from SDE 3.x database to a geodatabase
In ArcCatalog, when copying a layer from an SDE 3.x database to a geodatabase, Paste is disabled
Cause
The copy/paste functionality in ArcCatalog does not support copying SDE layers from versions of ArcSDE earlier than 8.0.1.
Solution or Workaround
Use the Geodatabase to Geodatabase tool in ArcCatalog to copy the SDE layer to a geodatabase feature class:
  1. Right-click the layer in the catalog tree.
  2. Click Export/Geodatabase to Geodatabase.
  3. Select you target geodatabase and, optionally, feature dataset.
    [O-Image] Feature class to Geodatabase dialog box
  4. Click OK.
Article ID:000003349
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
