PROBLEM
Cannot save and display Arabic transliteration characters
Arabic transliteration characters cannot be stored in regular shapefiles, coverage, or SDE. They can be stored in a personal geodatabase or Unicode-enabled shapefile.
Cause
Arabic transliteration characters are not included in the regular Arabic codepage. To store these characters, data must be stored in Unicode.
Solution or Workaround
Among the data formats supported by ArcGIS, personal geodatabase supports Unicode by default. Type or paste the special characters into a personal geodatabase. If the characters are not displayed correctly, make sure that the table font is set to Unicode font, such as Tahoma.
Another data format that can support Unicode is a shapefile, however, regular shapefiles do not support Unicode. In order to create shapefiles in Unicode, specify 'UTF-8' as .dbf default codepage before creating the shapefiles. The instructions on how to set the .dbf default codepage are found in the Related Information link below.
Article ID:000006638
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
