PROBLEM
While uninstalling ArcExplorer-Java Edition 4.0.1, the following error is displayed: "Cannot find the file 'C:\WINNT\system32\Unwise32.exe' (or one of its components). Make sure the path and filename are correct and that all required libraries are available."
The uninstall process automatically searches for this required executable file and will not properly finish unless it is present. If another program, such as ArcIMS 4.0.1, was recently uninstalled on the same machine that process may have removed this shared file.
Article ID:000006420
Get help from ArcGIS experts
Download the Esri Support App
