PROBLEM
Cannot add data to a new table in ArcMap
The Start Editing option is greyed out after adding a new table with the Add Data button. The table (INFO or geodatabase) was created through ArcToolbox or ArcCatalog, and ArcMap was started immediately after.This document shows how you can edit the table.
Cause
This is a known limit at ArcInfo 8.0.2.
Solution or Workaround
  1. Add a geographic data set from the same directory or workspace where the table is located.
  2. Click Start Editing from the editor menu.
  3. Highlight the table in the table of contents, right-click and click Open.
  4. Add records to the table and edit any existing records.
Article ID:000002078
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
