PROBLEM
Calculation works in Survey123 Connect but not in the web browser
Last Published: August 14, 2024
Using an "if selected" calculation to auto-populate a field works as expected in Survey123 Connect but does not work in the web form. For example:
if(${status}='good', 'green') OR if(${status}='ok', 'yellow') OR if(${status}='bad', 'red', 'white')
Cause
The web form cannot apply the same logic as Survey123 Connect.
Solution or Workaround
It is recommended to chain if statements together. Each if statement is the 'else' choice for the proceeding if statement until the end. That is where to add the default option if none of your if statements are true. For example:
if(${status}='good', 'green', if(${status}='ok', 'yellow', if(${status}='bad', 'red', 'white')))
Article ID: 000033075
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
