PROBLEM
Calculating logarithm mathematical operation returns unexpected result
Last Published: August 10, 2023
When running the log() or math.log() function to calculate the logarithm value of a field in an attribute table using the Arcade and Python parser in the Calculate Field tool, the result returned is the value for natural logarithm (ln) instead of the logarithm value. The following image demonstrates the wrong result.
Wrong result when using the log() function
Cause
This is an expected behavior when running the log() or math.log() function in the Calculate Field tool. The log() and math.log() functions in ArcGIS Pro are designed to return the natural logarithm to the base irrational number, or e, of the value instead of the logarithm to the base ten (10). Refer to ArcGIS Arcade: Log for more information.
Solution or Workaround
To calculate the base ten logarithm value with the Python parser, use the math.log10() function in the Calculate Field tool.
math.log10(!<FieldName>!)
The following image shows the sample usage and the correct result.
Correct result when using the math.log10() function
To calculate the base ten logarithm value with the Arcade parser, divide the natural logarithm value by 2.302585 using the following expression.
log($feature.<fieldName>)/2.302585
Correct result when using the log() Arcade parser
Article ID: 000030961
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 9x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
