PROBLEM
When the Field Calculator is used to calculate a field value to NULL using the equation [Field name] = is null, the following error displays:"Error running VBA code : User interrupt."
It is not possible to calculate a field value to NULL using the Field Calculator. The calculation must be done using VBA and ArcObjects.
Warning:
This code does not edit a selection set. It edits the whole table and the edits cannot be undone.
Code in the project's ThisDocument code module only runs in the current map document. To store the code in all map documents, open the Normal.mxt ThisDocument code module instead.
Code:
Option Explicit
Public Sub SetNull()
Dim pDispTab As IDisplayTable
Dim pMXD As IMxDocument
Dim pTable As ITable
Dim pCursor As ICursor
Dim pRow As IRow
Set pMXD = ThisDocument
Set pDispTab = pMXD.SelectedItem
Set pTable = pDispTab.DisplayTable
Set pCursor = pTable.Search(Nothing, False)
Set pRow = pCursor.NextRow
Do While Not pRow Is Nothing
'enter the name of the field below
pRow.Value(pTable.Fields.FindField("FieldName")) = Null
pRow.Store
Loop
End Sub
Article ID:000006393
Get help from ArcGIS experts
Download the Esri Support App
