PROBLEM
BIM data does not appear in the correct location in ArcGIS Pro
First Published: October 8, 2025
Last Published: June 26, 2026
In some cases, although the known coordinate system of the BIM data was defined correctly in ArcGIS Pro according to Esri documentation, the data does not appear in the correct location.
Cause
In Revit software, there is a parameter called Geospatial Location (this information includes the GIS Coordinate System Code and Lat/Long values of the project or survey base point). Despite its name, this information is insufficient to establish the geospatial position of the BIM model.
Solution or Workaround
For BIM data to draw in an accurate location on the map, the following is required:
  • The BIM data must be created so that the X,Y coordinates correspond to a defined geospatial coordinate system.
  • The data must include the Esri coordinate system definition in the form of a PRJ file; this must be the same coordinate system that the data was created in. There are multiple ways to associate a PRJ file with the data:
Article ID: 000038487
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
